    Aim Cylinder Head Thermocouple 14mm K Type - AimShop.com
    S-T-CH-X05SOT14A4516MS
    In stock, ready to ship
    £70.00
    £70.00
    High-Quality Motorsport K Type Thermocouple Temperature Sensor
    The Aim cylinder head thermocouple (CHT) motorsport sensor allows you to measure cylinder head temperature when the sensor is placed between the spark plug and cylinder head.
    CHT Sensor Key Features
    Measure cylinder head temperature
    Thermocouple male fitting
    Wide temperature range
    2 pin, K Type
    Temperature range: 0-300°C
    Sensor cable length: 400mm
    Designed for motorsport environments
    Professional quality for accurate readings
    To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug). To use them with an Aim TC Hub, you will need a TC yellow 712 3 pin patch lead (metal binder plug).
    MXS, MXG, MXP and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash/loggers, you need to use the dedicated harness supplied with your device.
    Installation
    The Aim Cylinder Head 14mm thermocouple features a turn in its lower part for an easier installation/uninstallation; it has to fit between the spark plug and the cylinder head.
    To keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple.
    While running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimise cable interferences.
    Please note: Before screwing the spark plug cable back ensure that the sensor is firmly fixed to the cylinder head. While screwing it, minimise the thermocouple movements to avoid damage to the sensor.
    • Temperature working range: 0-300°C
    • Cable sensor length: 400mm
    • Cable Type: Compensated
    • K Type thermocouple
    • Aim Cylinder Head 14mm Thermocouple Temperature Sensor
    Technical sheet Race Studio 3
