AiM Exhaust Gas K Type Thermocouple Temperature Sensor M5 Motorcycle
£65
AiM Exhaust Gas K Type Thermocouple. Our AiM device measures exhaust gas temperature using our sensor. Key Features:...
Key Features:
  • Temperature Sensor
  • Exhaust Gas Type K
  • Thermocouple male fitting M5
Exhaust Gas Type K
Our exhaust gas Type K Thermocouple, accurately measures exhaust gas temperature using a thermocouple placed in the exhaust header pipe for faster data reading.
All our AiM thermocouples are 2 pin K type sensors and fit car, bike and kart installations.
Please Note: To use the sensors with an Aim Mychron expansion or EVO4 and EVO4S data loggers you will need a 712-DIN 4 pin patch lead or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer / dash logger you will need a 712-DIN 3 pin patch lead.
AiM are committed to supplying, professional engineers quality Motorsport products. Out cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components and our products are the best on the market today.
    • Temperature working range: 0-1000°C (32-1832°F)
    • Cable Length: 250mm (9.8")
    • Cable Type: Compensated
    The drawing below shows the thermocouple in dimensions in mm.
    The thermocouple ends with a male Mignon connector. The image below shows the connector pinout and connection table.
