AiM Exhaust Gas Thermocouple Temperature Sensor M5 K Type Motocross
SKU: S-T-EGT - 3CVGAS807
- £70.00
- £70.00
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.
Measure exhaust gas temperature | Thermocouple male fitting |
Wide temperature range |
Temperature range of 0-1000°C
Sensor cable length 25cm
- Temperature working range: 0-1000°C
- Cable sensor length: 25cm
- Cable Type: Compensated
- Two pins male thermocouple connection
- K Type thermocouple
- AiM Exhaust Gas Thermocouple M5 Sensor (EGT)
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.Key Features :
The AiM K Type thermocouple temperature sensor is fitted with a two pins male thermocouple connection.It can measure the exhaust gas temperature by being placed in the exhaust header pipe around 150mm from the exhaust pipe.
To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug) or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger, you will need a TC yellow 712 3 pin patch lead (metal binder plug).MXS, MXG, MXP, MXL2 and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash/loggers, you need to use the dedicated harness supplied with your device.
