    Aim Exhaust Gas Temperature (EGT) K Type Thermocouple Sensor - AimShop.com
    S-T-EGT
    In stock, ready to ship
    £70.00
    £70.00
    Aim Exhaust Gas Thermocouple Temperature Sensor M5 K Type
    The Aim Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.
    Measure exhaust gas temperature Thermocouple male fitting
    Wide temperature range
    The Aim K Type thermocouple temperature sensor is fitted with a two pins male thermocouple connection.
    Temperature range of 0-1000°C
    Sensor cable length 25cm
    To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug) or to use them with an Aim TC Hub or directly to a MyChron kart lap timer/dash logger, you will need a TC yellow 712 3 pin patch lead (metal binder plug).
    • Temperature working range: 0-1000°C
    • Cable sensor length: 25cm
    • Cable Type: Compensated
    • Two pin male thermocouple connection
    • K Type thermocouple
    • Aim Exhaust Gas Thermocouple M5 Sensor (EGT)
    Technical sheet Race Studio 3
