Aim GS-Dash Car Racing Dash Display
£350
The Aim 5" GS-Dash Compact Car Display. Shows data from the Aim EVO4S and EVO5. It displays engine...
The Aim 5" GS-Dash Compact Car Display. Shows data from the Aim EVO4S and EVO5. It displays engine ECU, GPS, G’s and other sensor data.
Perfect display for the Aim EVO4S and EVO5
Easy and Instant Readability
The wide 268X128 pixel display makes it very easy to read despite its compact size. The user has a choice of seven background colours, while the integrated ambient light sensor keeps always brightness at an optimal level.
9 Data Pages
The GS-Dash allows you to choose the data you want displayed and is 100% customizable, keeping it simple and intuitive.
Fully Configurable Shift Lights and Alarm LED’s
The five LED shift lights can be changed to any colour and threshold. In addition, the four alarm LED’s can be configured to any colour and frequency desired.
Easy configuration
Shift Lights and alarms are to be configured using Race Studio 3 configuration panel.
Session Highlights
At the end of each session, the GS-Dash gives you top three lap times, min/max speed and min/mar RPM.
Keyboard Operation
The pop-up keyboard allows for:
  • Enabling/disabling backlight
  • Checking firmware version
  • Deleting Stored Data
  • Selecting your current track from a list of the nearest 30 available
Tough and Compact
Its durable body is made out of solid aluminum and the compact size makes it ideal for small space installations (small cars, bikes, etc.). The GS-Dash also has a IP65 waterproof rating.
Display resolution: 268 x 128 pixels
Backlight: 7 configurable RGB colours
Ambient light sensor: Yes
Shift lights: 5 configurable RGB LEDs
Alarm LEDs: 4 configurable RGB LEDs
Display pages: Fully configurable
Body: Aluminium
Pushbuttons: Metallic
Dimensions: 127.8 x 82 x 22.2 mm
Weight: 380 g
Waterproof:IP65
GS-DASH Technical Specifications
GS-Dash with spiral cable
