AiM Hub For Universal Steering Wheel Bracket
£10.00
Universal steering wheel hub mount, to fit dash logger display on the side column of a quick release steering wheel.
Key Features:
Centre Hub Mount
The universal steering hub mount, has been designed to fit a dash logger display on the steering column side of your quick release steering wheel. This is the centre hub to use if you only want to mount a dash on the steering column side of your quick release.
70 & 76mm PCD 6 hole fitting covers almost all 6 bolt steering wheels. The interchangeable stainless steel steering wheel button and display mounts are a stylish and cost effective solution to your mounting requirements. The design is based around the centre hub which mounts between the steering wheel and the quick release device. Please Note: If you have a low or no dish steering wheel, you will probably need the 3mm hub spacer to give sufficient bolt head clearance. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
- 70 & 76mm PCD 6 hole fitting covers almost 6 bolt steering wheels
- 2mm thick raw stainless steel
