AiM Infrared Tyre Temperature Sensor.
Our infrared tyre temperature sensor has been designed to measure the surface temperature if tyres.
Key Features:
Infrared Tyre Temperature Sensor |
The sensor is sold with a cable of 25cm. Standard length patch leads are available to purchase if required. |
AiM are committed to supplying, professional engineers quality Motorsport products. Out cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components and our products are the best on the market today. |
Aim Infrared Tyre Temperature Sensor
- Output signal: 0-5V
- Field of measure: 35°
- Working Range: -20/120°C
- Sensor electrical Range: 820 Mv /-20°C - 3230 Mv / 120°C
- Sensor dimensions: 26.6 x 17.2mm
- IP Rating: IP65
- Sensor Cable Length: 250mm
The drawing below shows the sensor dimensions in mm.
