NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Kart Data Hub 4x CAN Inputs
£50
Product code: 40cm X08HUB010 / 150cm X08HUB150 The Aim Kart Data Hub 4x CAN Connection Multiplier used for the acquisition of all essential data you need to evaluate your car
The Aim Kart Data Hub 4x CAN Connection Multiplier used for the acquisition of all essential data you need to evaluate your car performance needs the connection of many peripherals to your data logger. This implies the presence of a great number of cables.
To solve this problem Aim developed Data Hub, the new CAN connection multiplier that works as an interface between all Aim loggers and their peripheral equipment.
Each Hub connects the logger with four peripherals: i.e. LCU lambda controller, GPS08 Module and one or more TC Hub (thermocouple multiplier).
The Data Hub takes all the information you need to your logger with only one cable, minimising wires overall.
Two way Data Hub
Dimensions: 70x30x23,5 mm
CAN cable length: 40 cm
Source cable length: 165 cm
Weight: 86 g
Waterproof: IP65
Four way Data Hub
Dimensions: 123x30x23,5 mm
CAN cable length: 40/150 cm
Weight: 97 g
Waterproof: IP65
