Aim LCU-One S - AimShop.com
Vendor:Aim Sensors
Aim LCU-One S
£280.00
Accurate Lambda Measurement
Wideband Bosch LSU 4.9 Sensor
CAN Data Transmission
For 2 & 4-Stroke Engines
Aim CAN Open Wideband Lambda Controller - AimShop.com
For External Devices
Aim LCU2 Lambda Controller - AimShop.com
Two Wideband Bosch LSU 4.9 Sensors
For V-Type & Inline Engines w/ Dual Exhaust Manifolds
Aim CAN Open Dual Wideband Lambda Controller - AimShop.com
Aim LCU-One Lambda Controller Replacement Weld on Bung - AimShop.com
Weld-On Bung
For Lambda Sensor
Bosch LSU 4.9 Probe - AimShop.com
