NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Magnetic Speed Pick up 719 Plug 1m Cable
£60
The Aim Magnetic Speed Pick up (719 Plug /1m cable) is a Hall effect sensor that varies its output when it meets a magnetic field.
The sensor contains three wires and produces a digital signal.
The sensor consists a thin piece of metal what passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. Then you will be able to get a voltage.
The sensor only produces around seven volts. When the electrons move to one side a potential difference is produced between the two sides of the metal.
