AiM Magnetic Speed Sensor
The AiM non contact sensor that needs a metallic trigger to pass in front of it.
Key Features:
This is a non contact sensor that needs a metallic trigger to pass in front of it. It is sold with a magnet and the needed locknuts and is available in two versions: with plastic connector (Binder 719) and with metallic connector (Binder 712). |
The sensor consists a thin piece of metal what passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. Then you will be able to get a voltage. The sensor only produces around seven volts. When the electrons move to one side a potential difference is produced between the two sides of the metal. |
The 719 connection will suit MXL (Strada), MXG, MXS, MXP (inc Strada). Use with a 719-719 patch lead to extend to the required length. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM Magnetic Speed Sensor 719 Plug 1m Cable
