The MultiChron, Hand-Held Digital Lap Timer / Stopwatch, tracks up to four different racers simultaneously. Light, Handy and versatile it is suited for any racing situation.
Aim MultiChron - Hand Held Digital Car Lap Timer Stopwatch
Its generous memory lets you record 99 laps per driver with up to 9 splits per competitor per lap. Moreover you can quickly see best laps and scroll all competitors’ lap times to review the race.
Black, lightweight (100 g batteries included) despite its rugged, appealing case, equipped with a bright display, the MultiChron is the ideal tool for any kind of competition.
Special Start Modes
MultiChron stopwatch features 2 different starting modes to match a variety of racing situations:
- “One Start” mode allows you to activate the start for all competitors pressing one only button: for races where all competitors start at the same time.
- “Multi Start” mode allows you to activate the start for each competitor independently: for races where competitors start at different times.
Innovative programming allows you to get accurate times even when your racers are close together at the lap marker: selecting 'Multi Key' you can attribute times to each racer pressing 1,2,3 or 4 button. Selecting 'One Key' you get all 4 times pressing the same key and then you attribute times to each racer. It's a quite useful mode in case of final rush.
Dimensions: 25,5 x 29 mm
Weight: 100 g, batteries included
- 1/100 second precision
- Up to 99 lap times with up to 9 splits per lap
- Up to four competitors with single or multiple start
- Data recall while saving
- Automatic turn-off after 30 minutes inactivity
- Two 3V batteries allow you to keep your data safe
