Aim Mx Strada Logger Kit with Data Hub and GPS08 Module Motorcycle Kit
£895
MX Strada Logger Kit. Our Strada Logger Kit will upgrade and turn your MX Strada (MXS, MXP or...
Our Strada Logger Kit will upgrade and turn your MX Strada (MXS, MXP or MXG) dash into a full data logger.
Key Features:
  • GPS08 Module
  • Strada Logger
  • Data Hub
  • SD Card
  • 4 pin connector
  • Free race studio 3 download
Our Strada Track Logger Kit will upgrade and turn your MX Strada (MXS, MXP or MXG) dash into a full data logger. There is no configuration needed, just plug the Strada track logger kit into your dash and you are ready to go.
All the data from your practice sessions or race is recorded onto the data logger ready to be downloaded to Race Studio 3 software for further analysis.
Having the opportunity to review and analyse your data will help you improve as a driver, as well as identifying possible improvements in your vehicle setup, which could help take seconds off your lap times.
The memory card can be removed during a pit stop or with the engine running, giving you the opportunity to analyse your data while at the track.
Easy to install into your dash with no configuration, just plug in the logger and its ready to record your data.
There is also a front LED that shows its status, recording / firmware.
AiM Product Video
    Strada Logger
    • Max power consumption: 50 mA
    • Cable length: 40cm
    • SD card: IT supports up to 32 GB
    • Dimensions: 55.5 x 78.3 x 18mm
    • Weight: 103g
    Four Way Data Hub
    • Dimensions: 123 x 30 x 23.5mm
    • CAN cable length: 40 / 150cm
    • Weight:97g
    GPS08 Module
    • Weight: 60.5g
    • Strada Logger Box
    • Four Way Data Hub
    • GPS08 Module
