AiM MXP Strada IVA Compliant 6" Dash Display Kit
£904
AiM MXP Strada IVA Compliant Plug & Play Kit   The road legal - MOT approved, IVA compliant...
The road legal - MOT approved, IVA compliant digital dash display, is a complete road legal display solution.
Key Features:
  • 6" TFT display
  • 1000 + ECU connections
  • CAN output
  • 10 RGB shift lights
  • Two digital outputs
  • Define up to 8 custom pages
  • 14 pin harness
  • Math channel
  • 5 alarm LEDs
  • 8 analog inputs
  • Ambient light sensor
  • Free race studio 3
For OEM & Kit Car Builders
The Road legal-MOT approved, IVA compliant digital dash display is a complete road legal display solution for OEM, Kit car builders and race car builders.
The AiM MXP 1.2 Strada IVA Compliant Kit has a 6" colour TFT display which offers a great visual impact. It is also configurable to show all the data coming from the vehicles Engine Control Unit (ECU). 9 axis inertial platform (accelerometer, grows and magnetometer), 8 analogue inputs, 6 digital inputs, pre-defined math channels, a second CAN and an optional GPS.
Aim IVA Approved Plug & Play Kit Car Dash
This kit is the perfect solution for kit car builders. And our system allows you to see and monitor all ECU information and Odometer, Oil Temperature, Hazards, Main Beam, Engine Temperature, Front Fog, Dipped Beam, Fuel Level, Rear Fog, LH Indicator, Side Lights, Parking Brake, RH Indicator.
The MXP 1.2 Strada has a wide contrast TFT display, its visual quality is optimised as its ambient light sensor keeps the back light at the best brightness.
Connecting the MXP 1.2 Strada dash to your ECU is very simple. You can sample and display dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
As well as the standard 14 pin wiring loom, this kit comes with an additional 23 pin loom which has pre-configured connections foe all the relevant electrical items of your vehicle such as oil temperature, engine temperature, fuel level, side lights, hazards, front & rear fog, handbrake, main beam, and left & right hand indicator. Speed sensor has also been included for connecting to this additional loom.
Pre-Configured Pages
The MXP 1.2 Strada shows together with RPM scale showing the data you need like speed, water temperature, oil pressure, lap times and much more.
You can choose the custom pages you wish from a large library of page styles. You decide what data to be shown and the end scale and measure units. Also swapping between pages is easy using the Pushbuttons.
High Contrast TFT Display
The MXP 1.2 Strada features a high contrast TFT display, its visual quality is always optimal as its ambient light sensor keeps the backlight at the best brightness levels.
Flexible Shift Lights and Alarms
The MXP 1.2 Strada has 10 multi-coloured RGB shift lights which can be customised to your liking to define the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on / off depending on analogue or digital inputs, ECU values, expansion values, math channels or optionally GPS information.
You can choose the conditions, colours. You can select a solid alarm or a flashing one, also the flashing frequency. You can also configure an accompanying text message, and set the alarm priorities.
Two Digital Outputs
The MXP Strada IVA Kit features a 1 amp digital output configurable in order to be activated or deactivated depending on the value of the analogue / digital inputs or on impulses coming from the ECU. This allows you to automatically run external systems, such as switch on and off additional lights, to activate or de-activate a cooling fan or circulation pumps etc when a certain event happens.
MXS 1.2 Strada Connection Example
Below is an example of items that can be added to our MXS Strada for incrementing the performance and the data.
Compare AiM Dashes
AiM Product Video
AiM MXP IVA Compliant 6" Dash Display Kit
  • Display: 6" TFT
  • Contrast: 600:1
  • Ambient light sensor: Yes
  • Alarm display icons: Yes - Freely configurable
  • Shift lights: 10 RGB LEDs
  • Alarm LEDs: 5 RGB LEDs
  • CAN connections: 3
  • ECU connections: CAN, RS232 or K-Line
  • ECU compatibility: 1,000+ industry leading ECUs
  • Expansion CAN connection: GPS Module, Channel Expansion, Thermocouples expansions, Lambda Controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1,000 Hz each
  • Digital inputs: 1 Speed input, coil RPM input
  • Digital outputs: 1 (1 A max)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 AMP connectors + 1 Binder connector
  • Power consumption: 189.6 x 106.4 x 24.9mm
  • Weight: 590g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXP 360° View
MXP 1.2 Strada Display with Road Icons
  • MXS Strada 1.2
  • 23 Pin Loom IVA Loom
  • 14 Pin Loom
  • Wheel Speed Sensor
