AiM Oil / Fuel Pressure Sensor M10 0-10 Bar.
AiM M10 0-10 bar oil / fuel pressure sensor with 719 binder connector.
Key Features:
AiM Pressure Sensor M10 0-10 bar
- Supply: 8-16V
- Accuracy: <+/-0.5% FS (CLNH - combined non-linearity and hysteresis)
- Characterisation: 500 mV / 0 bar - 4500 mV / 10 bar
- Temperature working Range: < from -20°C to 135°C
- Sealing: IP66
- Weight: 30g
- Cable length: 400mm
- Thread: M10
