- Description
- Technical Specifications
- ECU Connections & Support
- Whats in The Box
- Downloads
- Accessories
AiM PDM 6" Display Cowl
Check out our PDM 6" Display Cowl offering a solution to sun glare and protection with a perfect finish for your dash.
Key Features:
The AiM PDM 6" Display CowlOur AiM PDM 6" Display Cowl offers protection from sun glare and gives the perfect finish for your dash. It will protect the dash and screen from frontal impacts, such as stones. While helping to reduce sun glare it highlights the brightness of the screen. |
The AiM PDM 6" Display Cowl is lightweight and made with honeycomb construction and a textured finish. It makes a stylish home for your PDM. |
AiM MXP Display Cowl
- Lightweight
- Honeycomb Construction
