AiM PDM32 Race Icons Data Logging Kit
£1,650
AiM PDM32 Power Distribution Module. The AiM PDM32 has been designed to distribute power to multiple circuits on...
The AiM PDM32 has been designed to distribute power to multiple circuits on your vehicle.
Key Features:
  • 28 High Side Outputs
  • 4 Half Bridge Outputs
  • Controls multiple vehicle circuits
  • Data logging facility
  • 32 Status LEDs
  • Free Race Studio 3 Download
  • ECU connections, for getting data from your ECU
  • Dash controller, for easily managing a 6" or 10" dash
  • Data logging, for avoiding adding another logger to your car
  • 9 axis EMU platform
  • GPS Module, providing automatic lap times and track positions
  • Mirror and reverse camera
  • TFT Display
The AiM PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits removing the need for traditional fuse boxes and relays.
It allows for a simplified wiring harness with increased reliability and control functions. The PDM32 is available on its own or with a choice of 6" or 10" dash displays. It can also be capable of receiving data from the vehicles ECU and even includes a data logger and GPS module for lap timing and track mapping.
Power Outputs
The PDM32 features 28 high sided outputs and 4 half bridge outputs.
. High Power: Continuous current 20A 4
. Medium Power: Continuous current 15A 12
. Low Power: Continuous current 10A 12
. Half Bridge: 4
. Total continuous max current 120A
Each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high / low voltage, the number of fault retires and the time between the reties is user definable. All outputs can be configured as PWM's for a soft start / stop. All of the PDM circuits can be set up and monitored via our Race Studio 3 Software.
Special Functions
Some "black boxes" are available for simplifying the configuration.
For example, the Wiper may be managed by the LIN connection or using the Half Bridges.
In this case, you may take advantage by a virtual object like the following one:
PDM Inputs
. Analog/Digital: 8
. Only digital: 4
. Speed 2
If configured as Analog inputs, it is possible to activate an internal 2K Ohm resistor, for connecting most of the sensors directly.
If configured as Digital Inputs, it is possible to activate a 10K Ohm Pull Up or a 10K Ohm Pull Down.
Data Management
The PDM32 is capable of receiving and recording data from the following sources:
ECU - Over 1000 protocols available / Digital / Analogue Inputs / Internal 9 axis EMU / GPS - Lap time and position / Expansions / Push buttons - From R1O02 module or any commercial CAN keypad / PDM outputs - Currents and status of each channel individually / Other user defined math channels.
GPS Options
The GPS module option provides easy lap timing and lap position for track mapping with over 4000 tracks in the database.
Dash Display Options
Suitable for replacing all of the dashboard gauges and warning lamps these TFT dash displays are available in 6" and 10" versions.
Both versions have fully user configurable displays and offer a range of layouts.
Turn Your Dash/Logger Into A Rearview Mirror
Data Logger
An internal data logger is available, capable of recording all the analog inputs, digital inputs, ECU channels, GPS values, Currents, status of all the Power Outputs. Here an example of what the recorded data may show, during engine cranking.
AiM PDM32
  • Inputs - 14 fully configurable, max 500 Hz each:  8 analogue / Digital, Digital inputs of which 2 sped input
  • Power Outputs - 4 rated up to 20 A (high power) 12 rated up to 15 A (mild power) 12 rated up to 10 A (low power) 4 rated up to 35 A (half bridge) Protected for: over voltage, under voltage, over current, over temperature. Total max current: 120A
  • Lin Bus - 1
  • CAN Connections - 3
  • Intertial Platform - 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetomter
  • Internal Memory - 4 GB
  • External Modules - GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module
  • External Analogue Camera Input - 2
  • Body - Anodised Aluminium
  • Waterproof - IP65
  • Dimensions - 234.5 x 94.6 x 49.5mm
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM PDM32 360° View
  • PDM32
  • X 2 35 Pins AMP Connector
  • Surlok Connector
  • Rosenberger LVDS Connector
  • CAN EXP Cable
  • Download Lead
  • GPS08 Module
  • TFT Screen 6" or 10"
