    Aim RPM Coil Adaptor For EVO4 - ARP04 - AimShop.com
    EVO4-RPM-AD
    £75.00
    £75.00
    This Aim adaptor has been designed to supply RPM signals to an Aim EVO4 data logger on vehicles without an ECU.
    Suitable for EVO4 logger For older vehicles
    This Aim adaptor has been designed to supply RPM signals to an Aim EVO4 data logger on vehicles without an ECU. It connects to the coil and filters the signal, reducing noise and generating the correct square compatible with the EVO4 logger.
    Connecting The RPM Coil Adaptor
    Connect the cable that ends with a five-pin binder 712 male connectors to RPM input of EVO4
    Connect the black cable labelled GND to vehicle reference ground
    Connect the red cable labelled 9-15 VDC to a switched 12V power supply
    Connect the white cable labelled RPM 150-450V to the coil earth trigger
    The yellow cable labelled DIGIT OUT is EVO4 digital output
    • Connecting the RPM Coil Adaptor
    • Connect the cable that ends with a 5 pins Binder 712 male connector to RPM input of EVO4
    • Connect the black cable labelled GND to vehicle reference ground
    • Connect the red cable labelled 9-15VDC to a switched 12V power supply
    • Connect the white cable labelled RPM 150-450V to the coil earth trigger
    • The yellow cable labelled DIGIT OUT is EVO4 digital output
    • 1 x RPM Coil Adaptor for EVO4S
    Technical sheet Race Studio 3
