Aim Shift Light Module
Compact Shift Light Module
The Aim Shift Light Module is a compact array of 10 RGB LEDs that help monitor RPM thresholds, alerts and other indicators, giving you complete control over your gear shift optimum revs.
Why Choose the Aim Shift Light Module
You can easily set the LED colour and the RPM value that turns each LED on/off, depending on the gear number. The Shift Light Module is ideal when you have a logger but not a dash display, or if your dash display is positioned where you can't easily see its shift lights.
Connection
The Shift Light Module uses a CAN connection, which is a 712-712 male 5-pin patch lead. These are sold separately and are available in 0.5 and 2m, you can select any of these options above.
It can be used with MX dash series, both Logger and Strada versions, as well as with PDM displays.
Note: You will require the patch lead to enable connection to your dash display or logger.
The Shift Light Module can also be set as a predictive lap timer using our Race Studio 3 software. Customise the LED bar to turn green if you are improving your chrono compared to the best one of the session, or it can turn red if you are getting worse.
Please Note: The predictive lap time function is only available for the MX series of dash displays.
Shift Light Module
