Free Shipping Next Day Delivery +44 (0)1782 393843 Shop now, Pay Later
AiM SmartyCam GP HD 2.1 + 2.2 Mini Roll Cage Mount (With Clamp) Bike
£50.00
SmartyCam GP HD Mini Roll Cage Mount.
The SmartyCam GP HD mini roll cage mounts are designed to fit the AiM SmartyCam GP HD Bullet Camara.
Key Features:
  • Fits SmartyCam GP HD Camara
  • Universal roll bar fitment
  • Standard or extended length
  • Free Race Studio 3 Download
The mini roll cage mounts are designed to fit the AiM motorsport SmartyCam GP HD and enable it to easily be mounted to a roll bar tube.  The mount is manufactured from aluminium with a black anodised finish and is designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the AiM SmartyCam GP HD camera to a roll cage.
The 2x jubilee clips allow for fitting to different roll cage tube diameters.
Includes an aluminium clamp which the camera fits in to.
Standard or extended lengths available.
This kit includes two tube clamps, 44mm & 55mm to enable you to attach the mount to different size roll bars, railings or tubes.
User Guide
Technical sheet
