    Aim SmartyCam Mini Roll Cage Mount - AimShop.com
    SM-VB
    In stock, ready to ship
    £50.00
    £50.00
    The SmartyCam HD, Sport or Corsa can be installed using the HD roll cage mount. It is suitable for the SmartyCam 2.1, 2.2 & 3.
    Fits the SmartyCam 2.1, 2.2 & 3 camera
    Universal roll bar fitment
    Standard or extended length
    SmartyCam HD Compatible
    SmartyCam 3 Sport Compatible
    SmartyCam 3 Corsa Compatible
    The Aim mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube.
    The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
    Provides an easy method of mounting the SmartyCam to a roll bar.
    The supplied jubilee drive clips allow for fitting two different roll cage tube diameters.
    Standard or extended lengths are available to choose from.
    For use with SmartyCam HD, Sport & Corsa (2.1, 2.2 & 3).
    • Roll cage mount (standard or extended version) One supplied
    • 2 x Jubilee clips
    SmartyCam Mount Tech Sheet
    Technical Sheet Race Studio 3
