Spark Plug Inductive RPM Adapter
The AiM RPM Adapter has been designed for single cylinder 2 or 4 stroke engines.
Key Features:
The AiM spark RPM adapter has been designed for installation on single cylinder 2 or 4 stroke engines. It is a filter that converts RPM signal sampled by induction from the spark plug in a square wave signal. The image below shows the signal sampled by induction on the left and the square wave signal on the right. |
To install the adapter connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. |
AiM Spark Plug Inductive RPM Adapter
The drawing below shows the adapter correctly installed.
