Aim TC Hub Thermocouple Multiplier Type K – AimShop.com
SKU: TCH-4
Availability: 49 in stock
£228.00
QTY:
Trust Badge
The Aim TC Hub - Thermocouple Multiplier allows for four additional thermocouples can be connected via CAN to all Aim data loggers.
Keep all temperatures of your engine under control.
Using more TC Hub you can easily keep under control all your temperature sensors data, monitoring each single cylinder exhaust gas temperature, together with water, oil and head temperatures.
The Aim TC Hub - Thermocouple Multiplier is waterproof and robust thanks to its aluminum structure, TC Hub provides reliable data as its sampling frequency is configurable up to 50Hz per channel. Finally, with TC Hub your wiring overall is reduced to the minimum.
Connectrion Example
TC Hub - Thermocouple Multiplier Connectrion Example
