Tyre Temperature Bracket Kit.
This AiM tyre temperature bracket kit has been designed tube used with the tyre temperature sensor kit.
Key Features:
The kit includes four brackets and fittings, enabling the optimum mounting of the sensors, in the correct place to get the correct temperature readings from all 4 tyres. |
Please refer to the Technical download sheet on how to install the Tyre Temperature Sensor Brackets. |
AiM Tyre Temperature Sensor Brackets Kit
