The Universal Dash Bracket, is engineered to be used in conjunction with our steering wheel column brackets, using the Steering Wheel Hub Mount and tabs.
Our interchangeable stainless steel steering wheel button and display mounts are a very stylish and cost effective solution to your mounting requirements. The whole design is based around the centre hub which mounts between your steering wheel and (usually) your quick release device.
**Please note that if you have a low or no 'dish' steering wheel, you will probably need the 3mm hub spacer to give sufficient bolt head clearance**
The hub is made to suit 70mm PCD and 74mm PCD 6 hole steering wheels. This covers almost all of the 6 hole market. We have a range of bolt on items to then connect to this hub including a range of left, right or bottom button sets.
