AiM Water / Oil M5 Temperature Sensor
The AiM Motorsport M5 K type thermocouple sensor.
Key Features:
The AiM K type thermocouple M5 temperature sensor is fitted with an easy to use 2 pin male thermocouple connection. |
To use this sensor with an AiM MyChron expansion or EVO and EVO4S you will need a TC Yellow to 712 4 pin patch lead. Or to use with the AiM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer / dash logger you will need a TC Yellow to 712 3 pin patch lead. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM Water Oil Temp M5 Type K Thermocouple
