    AiM Yarara Yamaha ATV ECU Plug & Play - AimShop.com
    Y-ECU
    Aim Yarara Yamaha ATV ECU Plug & Play
    In stock, ready to ship
    £480.00
    £480.00
    AiM Yarara Yamaha ATV ECU Plug & Play Engine Control Unit
    Yarara is the plug & play ECU developed by AiM for being installed on the Yamaha YFZ450R. Thanks to its high technology 32-bit core, it is a good help for improving the performances of your ATV, without sacrificing reliability and smoothness.
    Yarara is specifically designed for:
    Yamaha YFZ450R Model year 2021 and 2022
    Yarara Key Features & Advanced Strategies
    Injection main  Injector 2 percentage
    Injection user compensation Injector 2 phase
    Injection main speed density Injector opening transient correction
    Injection crank correction
    Injector closing transient correction
    Pre-injection Ignition main
    Injection BAP correction Ignition user compensation
    Injection EWT correction Ignition BAP correction
    Inection IAT correction Ignition EWT correction
    Injector 1 battery correction Ignition IAT correction
    Injector 1 phase Ignition opening transient correction
    Injector 2 battery correction Ignition close transient correction
    High Technology 32-bit Core
    Engine control requires precision. At 20,000 RPM the Yarara ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
    Tuner License :
    This is the Tuner that is required to configure the unprogrammed Yarara ECU.
    With this license, the tuner can create different maps, configurations and strategies. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
    The Aim Handlebar Switch is the best way for changing the behaviour of your UTV; it features 2 pushbuttons, 10 LEDs and manages the following settings :
    Below shows a functional diagram of products that can be added to the Yarara ECU:
    AiM Yarara ECU Plug & Play Engine Control Unit
    • One low side driver (1 A)
    • Power consumption 150 mA
    • Connectors:
    • n.1 JAE male 18 pin MX23A18NF1 Connector
    • n.1 34 pin male Connector
    • Body: PA6 + 30% glass fiber
    • Dimensions: 141.5x84.3x26.9 mm
    • Waterproof: IP67
    • Weight: 370g
    • ECU Yarara Control Unit
    Video
    User Guide Tuning Manual Technical sheet Race Studio 3 Spark Tuning Software
