The Ultimate Mountain Bike Setup
Combine the X Log, a small, waterproof, 25Hz GPS data logger; the ACC3, our unbeaten Analogue CAN Converter; Suspension Potentiometers, and you can even connect the ultimate camera - the SmartyCam 3 Sport, to become the best rider and beat your best lap times.
Why Choose the X Log Mountain Bike Kit
The Aim X Log data logger is essentially a Solo 2 DL without the screen: offering the same logging power, precision, and expandability in a smaller, lighter package. For riders, racers, or anyone working with limited space but still demanding full-scale data analysis, the X Log is the perfect solution.
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. Combined with the ACC3 and Suspension Potentiometers, you will find the ultimate key to control, analysis and improvement.
XLog data logger
Downhill mountain bike
X Log Features
The X Log calculates and records:
  • Lap times
  • Sector times
  • Vehicle position and speed
  • 3D acceleration and gyro
In addition, the X Log features a second CAN for connecting external device or Aim Expansion, meaning you can add brake pressure sensors, analogue inputs, and a professional motorsport camera for enhanced functionalities.
ACC3 with 4 channel harness
The Aim ACC3 is an Analogue CAN Converter, built practically for a range of motorsport disciplines, including downhill mountain bike applications. Its compact design ensures easy installation across a range of racing disciplines, while its robust construction guarantees reliability in demanding environments. When combined with Race Studio 3 software, the ACC3 unlocks powerful configuration and analysis tools, including suspension analysis with Aim Eclipse sensors and video synchronisation with SmartyCam 3 cameras.
The ACC3 supports up to 4 analogue inputs with frequencies up to 200Hz.
Inertial Platform in XLog
X Log GPS & Inertial Platform
  • Lap Timing & Sectors: Samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
Compact, Durable Design
Measuring only 72.3 × 65.3 × 30.3mm, the X Log is compact to fit in even the tightest setup. Its rugged, waterproof housing ensures reliable operation in all conditions. With a built-in rechargeable lithium battery (up to 10 hours) and support for an external 8–16V supply, the X Log is built for trackside convenience.
Analyse with Race Studio 3
All data logged by the X Log can be downloaded wirelessly or via USB-C, then reviewed in Aim’s professional Race Studio 3 software.
Analyse lap times, sector times, GPS maps, accelerations, and video (when paired with a SmartyCam 3) to improve your performance and understand your bike in detail.
Expand your XLog with ACC3, Data Hub and sensors
The XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can integrate brake pressure sensors and a professional motorsport camera for enhanced functionalities.
Integrate the ACC3 that comes in the kit to sample data coming from suspension and pressure; you will also be able to integrate a SmartyCam 3, sold separately, taking your data to the next level by incorporating synchronised video footage to overlay the data recorded by the XLog data logger onto your footage post-session with Race Studio 3.
X Log
  • USB Connection: Yes
  • GPS: 25Hz
  • Wi-Fi: Built in
  • Bluetooth: Built in
  • Expansions: ACC3, Lambda Sensors, SmartyCam
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • External Power: 9-15V
  • Weight: 150g approx.
SKU: XLOG
ACC3
  • Connection: CAN
  • Material: PA6 30% glass
  • Weight: 50g
  • Waterproof: IP65
SKU: ACC
X Log User Guide
X Log Tech Sheet
ACC User Guide
ACC Tech Sheet
Rose End Tech Sheet
Pop End Tech Sheet
