    Link BMW MiniLink - MINIX PlugIn ECU - AimShop.com
    MINIX
    MINI Hatch R50 – R53 Link - MINIX PlugIn ECU
    In stock, ready to ship
    £1,355.00
    £1,355.00
    Our ECU comes in its own case which fits directly into the factory location.
    Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
    This ECU is designed for the R50-R53 Tritec 1.6 SC engine.
    Please check your pinout connector matches the header in the listed photo before purchasing.
    An XS Loom and 4 Bar Map Sensor highly recommended (sold separately).
    Suitable Applications:
    R50 –R53 MINI Hatch with the 1.6l SC engine
    *Chronopack dash option not currently supported
    PlugIn Key Features (where applicable):
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Aux1 -  Auxiliary Output
    DI8 -  Digital Input
    DI9 -  Digital Input
    An Temp 3 -  Temperature sensor input
    An Temp 4 -  Temperature sensor input
    An Volt 10 -  Analog 0-5V input
    An Volt 11 -  Analog 0-5V input
    +5V Out -  Low Current +5V Supply
    GND -  Sensor Ground Only
    *Please see the PC Link Help file for details regarding installing the Expansion Cable.
    MINI hatch R50 – R53 Link - MINIX PlugIn ECU
    • G4X PlugIn ECU
    • Stickers
