    SDI to BNC Adaptor - AimShop.com
    SDI-to-BNC
    SDI to BNC Adaptor
    In stock
    £15.00
    SDI to BNC Adaptor
    £15.00
    This adaptor converts the SDI output connector of a SmartyCam 3 GP HD or SmartyCam 3 Dual into A BNC female connector. This makes it easy to connect to industry-standard connections of live streaming video equipment.
    We can also make a BNC cable, if required, at your desired length.
    Characteristics
    Impedance 50 Ω
    Dielectric withstand voltage 2500V RMS, 50Hz, at sea level
    Dielectric Resistance ≥5000MΩ
    Connector Type SMA Male – BNC Female
    Durability Mating Cycle ≥500
    Electrical & Mechanical Specs.
    Material and Plating
    Body Brass / Nickel plating
    Insulator PTFE
    Centre Contact (pin) Beryllium, Brass / Gold plating
