Tyre Pressure Monitoring System CAN Handheld Reader.
The handheld Reader / Programmer is available to read each wheel individually .
Key Features:
Each sensor is labelled FR, FL, RR, RL for each of the wheels of the car. Extra wheels can be clone coded that can then be used as sets of spares for pit changes. The wire colour codes are: +12V - Red |
Back Light |
Use the green TX button when you are not in programming mode to turn on and off the backlighting.
AiM Dashes and Loggers will require a CAN Protocol which can be obtained from AiM Technologies in order to interface with the unit. |
Adding Spare Sets of Wheels
To clone a sensor first you need to know the sensor ID, by reading the one that is programmed. Write down the sensor ID ... Example 1234AB56 Exit back to the TPMS screen. Press the "TX" button and hold for 3 seconds. A set of data addresses will appear on the screen. Navigation is done with the "L" and "R" buttons. The value is changed with the "U" and "D" buttons. (0123456789ABCDF) 1. Put in the location D1: the value 13H. (this is a fixed value) Press the "TX' Button and hold for 3 seconds, the screen changes to 'Reading". Hold your new sensor close to the handheld unit. You have now cloned your sensor. To programme another sensor with same address then press next and put another new sensor near the handheld unit. To exit, press "EXIT" until you are at the TPMS Screen.
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
TPMS Hand Held Programming Unit.
- Tyre pressure monitoring system
- Check serial number
- Battery voltage
- Check pressure and temperature of tyre
- The wire colour codes for receiver are: +12V - Red, Ground - Black, CAN+ - Green, CAN- - White
- TPMS Hand Held Programming System
- Charging cable
