Yamaha YZF-R6 2004-2005 (YEC included) Solo DL Plug & Play Cable
£50
Yamaha YZF-R6 (YEC included) Solo 2 DL Plug & Play Cable. The Yamaha ECU Interface cable is a specific...
The Yamaha ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM Solo 2 DL lap timer or EVO4S data logger.
Key Features:
  • Plug & Play interface cable
  • Simple Wiring
  • Receive Data
  • Free Race Studio 3 Download
Yamaha Solo 2 DL Plug & Play Cable Available For:
  • Yamaha - YZF-R6 (YEC included) - 2004-2016
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
AiM Solo 2 DL Product Video
    • Yamaha YZF-R6 2004-2005 (YEC included) Solo DL Plug & Play Cable
