Yamaha YZF-R1, R1M & R6 From 2015 SOLO 2 DL P&P Kit
£500
The Yamaha YZF-R1, R1M & R6 From 2015 SOLO 2 DL P&P Kit allows easy connection of the...
The Yamaha YZF-R1, R1M & R6 From 2015 SOLO 2 DL P&P Kit allows easy connection of the Solo 2 DL to your bike ECU.
The Solo 2 DL connection kit for the Yamaha YZF-R1, R1M and R6 (from 2015) is a plug & play lap timer and data logger for track days and the open road.
Display and record real-time data such as RPM, traction control mode, throttle position, active gear, air temperature, engine coolant temperature and more. You can take advantage of the information coming from your Yamaha’s ECU to examine your performance with your Race Studio 3 software. Simply upload your session’s data via WiFi to view graphs, tables or histograms of your ride and see where you can boost your riding performance.
The kit includes an ECU connection cable (DLC connector), mounting bracket and fittings for straightforward and easy installation.
The kit is compatible with:
  • Yamaha YZF-R1 & R1M From 2015
  • Yamaha YZF R6 From 2017
What’s more, the Solo 2 DL provides you with plenty of other features:
  • Compare lap times with the best in session.
  • GPS speed, lap number, delta, rolling and predictive times.
  • Use the LED's to display RPM or shift lights.
  • Simple data transfer to laptop or computer using integrated WiFi feature.
  • 7 LED display colours available for optimum visibility.
  • Select your performance mode: point to point events or track racing.
  • Available port to connect the Smartycam or EVO4s.
  • 3000 tracks pre-configured tracks stored in device memory.
  • Ultimate accuracy with the most sophisticated GPD technology on the market.
  • Analyse your performance with the included Race Studio 3 software.
List of available ECU channels configurable with Yamaha – CAN_2015 protocol (Yamaha YZF-R1/R1M from 2015 and YZF-R6 from 2017):
Wheel Speed Front
Wheel Speed Rear
RPM
Traction Control Mode
Gear
Gear raw value
Power mode
Throttle position sensor
Throttle Handgrip
Lift Control Set
Launch Control Set
Slide Control System Set
Quick Shift Set
Rear ABS intervention
Front ABS intervention
Launch control intervention
Lift control intervention
Slide control system intervention
Traction control system intervention
Map selection
Engine Coolant Temperature
Ambient Air Temperature
Accelerometer X
Accelerometer Y
    • Display: Graphical
    • Display resolution:128x64 pixels
    • Display pages: Up to 8 freely configurable
    • Back light:7 configurable RGB colours
    • Shift lights/alarm LED's:10 configurable RGB LED's
    • Integrated track database:Yes
    • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    Solo DL 2  Motorcycle ECU connection: CAN, RS232 or K-Line to 1,000 + industry leading ECUs
    Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
    • Aim Solo 2 DL GPS Lap Timer
    • Yamaha Ecu and power connection lead
    • Yamaha mounting bracket kit
    • User manual
    • Software installation CD
    • AIM sticker
    yamaha
