Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim 22 Pin Deutsch Harness with 2 Thermocouples for MX Series - AimShop.com
    H22-DT-V02573160-MC
    Aim 22-Pin Deutsch Harness with 2 Thermocouples for MX Series
    I lager, redo att skickas
    £320.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £320.00
    Aim 22 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG
    The Aim 22 pin Deutsch Harness has been designed to allow you to connect two thermocouple sensors to your device.
    Suitable for MXS, MXP, MXG Optional harness
     Two K type thermocouples 22 pin harness
    22 pin Optional Harness with Two Thermocouple Connectors for the MX Series
    The Aim 90° 22 pin harness plugs into the 22-pin connector on the MXS, MXP or MXG dash loggers.
    This harness has been designed to enable you to connect up to two K type thermocouple sensors to your device.
    Several of the advanced functions rely on this harness, which is not included with the standard 37 pin harness which comes as standard with the dash loggers.
    The 22 pins optional harness provides access to the following functions:
    Digital 12V outputs 1, 2
    RS232 ECU connection
    Please Note: The standard harness that comes with the MXS, MXG and MXP allows 4 inputs. If you would like more inputs for your race data then add this optional harness to your kit.
    We have a choice of thermocouple sensors that can be added to your kit. The Aim Exhaust Gas K Type Temperature Sensor M5, Water Oil Temperature M5, Water/Oil Temperature Sensor M10.
    • 22 pin Deutsch Female Flying Connector
    • Table of non-ended cables  - See the table in Downloads Tab
    • Thermocouple Connectors - See the table in Downloads Tab
    • 22 pin Deutsch Harness with Two Thermocouple connectors
    Technical sheet Race Studio 3
    • Öppnas i ett nytt fönster.
