Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim 37 Pin Deutsch Harness with 2 Thermocouples For MX Series - AimShop.com
    H37-DT-V02573050
    Aim 37-Pin Deutsch Harness with 2 Thermocouples For MX Series
    I lager, redo att skickas
    £375.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £375.00
    Aim 37 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2, MXm
    The Aim 37 pin Deutsch harness with two thermocouple connectors to connect K-Line type sensors.
    Suitable for MXS, MXP, MXG MXL2 & MXm Digital output
     37 pin harness Two thermocouple connectors
    37 pin Harness with Two Thermocouple Connectors for the MX Series
    The Aim 37 pins harness has been designed with two thermocouple connectors, this will enable you to connect two different thermocouple sensors to your device.
    Thermocouple sensors available are Exhaust Gas Temperature Sensor, Water/Oil M5 Sensor, Water/Oil M10 Sensor, and many more depending on the application.
    The Aim 37 pins Deutsch harness functions are listed below:
    Digital wheel speed channel 1
    CAN expansion
    Power+
    Ground-
    CAN ECU connection
    K-Line connection
    Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
    Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.
    Aim expansion example
    These are some of the items that can be added to your car or motorcycle for incrementing performance and data.
    Aim 37 Pin Deutsch Harness with 2 Thermocouples for MXS, MXP, MXG, MXL2 & MXm
    • Two Thermocouple Connectors - See table in Downloads Tab
    Pinout for 37 Pin Deutsch Harness with 2 Thermocouples
    • 37 pin Deutsch Harness with Two Thermocouple Connectors
    37 Pin Deutsch Harness with 2 Thermocouples technical sheet
    Race Studio 3 Software Download
    Technical sheet Race Studio 3
    • Öppnas i ett nytt fönster.
