Aim MyChron Patchkabel 712 Hane 3-polig till 719 Hona 4-polig
Connect Your System
The Aim MyChron Temperature Sensor Patch Lead allows you to connect temperature sensors to your MyChron Lap Timer with ease, delivering a reliable link for accurate temperature readings. With a 3-pin 712 male Binder on one end and a 4-pin 719 female Binder on the other, this patch lead is designed to work with the MyChron Karting Lap Timer and Aim Temperature Sensors.
Why Choose the MyChron Temperature Sensor Patch Lead
This patch lead is purpose-built for karting and performance applications using the MyChron system. It offers pre-terminated connectors (3-pin 712 male Binder to 4-pin 719 female Binder) that save on installation time and avoid wiring mistakes, perfect for race day setups. With a cable length of 1500mm, it is especially suitable for karting, but also fits in motorcycle or compact track car environments where a dedicated temperature sensor connection is essential.
Please Note: Ensure your sensor and lap timer are compatible with the 712/719 connector configuration before installing.
712-719 Man till Kvinna Patch Lead
