Aim 712-712 Male to Female 4-Pin Patch Lead
Connect Your System
The Aim 712-712 patch lead is a durable extension cable designed for connecting sensors or expanding existing wiring in your Aim data system. Featuring secure metal screw-on connectors, it always ensures reliable signal transmission.
Why Choose the Aim 712-712 Patch Lead
The Aim 712-712 patch lead simplifies installation and setup, allowing easy connection between sensors, expansion hubs, or modules without complex rewiring. It’s ideal for clean, organised sensor layouts. The 4-pin male to female lead is available in multiple lengths and is compatible with Aim systems such as MXL Strada, MXL Pista, and EVO4 data loggers.
Essentially, the 712-712 patch lead is used to extend your connections or integrate additional modules, ensuring flexibility and reliability across your Aim racing setup.
712-712 Man till Kvinna Patch Lead
