Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim 719 (Plastic) Binder Plug - AimShop.com
    P-719
    £10.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £10.00
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for adding additional sensors or extension cables to your Aim system.
    Key Features:
    Suitable for Aim sensors 4 pin  plastic Binder
    Ideal for adding to your system
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your Aim system. The plug has four pins.
    Ideal for replacing broken plugs or when adding sensors to your Aim system.
    Fits Aim 719 cables and sensors
    • 719 Plastic Binder Plug
    • 1 x 719 Plastic Binder Plug
    • Öppnas i ett nytt fönster.
