Aim CAN-BT Module
Aim CAN-BT Module
Off-Road ECU Add-On for the Spark App
The Aim CAN–BT Module is the essential bridge between your Taipan or Yarara ECU and your smartphone, unlocking wireless access to live engine data through the free Spark App. Designed specifically for off-road motorcycles, the CAN-BT Module transforms your mobile device into a powerful diagnostic and tuning tool, wherever you ride.
Download the FREE Spark App on iOS or Android
Spark is now available as a mobile app for both Android and iOS, with seamless Bluetooth connectivity to your bike.
Connect your smartphone to the Taipan and Yarara ECU in two ways:
- Via the CAN-BT Module, for instant access to key engine data and real-time telemetry.
- Using the X Log if you want to collect data while riding as well.
Why Choose the Aim CAN-BT Module
The Aim CAN-BT Module connects directly to your ECU’s CAN network and
transmits data via Bluetooth, allowing instant visibility of key performance
metrics without the need for a laptop or wired connection. It's compact,
rugged, and designed for the harsh conditions of off-road use.
With the Spark App installed on your iOS or Android device, you gain a
streamlined, data-driven interface for real time monitoring, diagnostics, and
on-the-fly adjustments.
CAN-BT Module Key Features
- Live Dash Telemetry: View real time data such as RPM, throttle position, temperature, and more right on your smartphone dashboard.
- Diagnostic Warnings & Alerts: Instantly detect and identify ECU faults with clear, actionable alerts, helping prevent damage and downtime.
- Map Switching: Seamlessly switch between preset engine maps to adapt performance for different terrain or conditions.
- Fuel Adjustments: Fine-tune fuelling parameters directly from the app for optimal response and efficiency.
CAN-BT-modul
Anslutningskabel
