Aim Handhållen digital stoppur med flera mätare
Please Note: This is a pre-order item. You will be notified when stock is available.
Handheld Motorsport Multi-Tool
Upgrade your data logging with the Aim MyGauge, the ultimate all-in-one precision tool for racers, engineers, and motorsport professionals, engineered to withstand the rigours of motorsports. By integrating a tyre gauge, pyrometer, weather station, and multi-driver stopwatch into one rugged device, it delivers the critical data you need to dominate every session.
Why Choose the Aim MyGauge Multi-Tool
The Aim MyGauge All-In-One Multi-Tool is a rugged and weather-resistant device that combines four essential tools into one portable device:
- Tyre Pressure: Measures, adjusts and stores tyre pressures.
- Infrared Pyrometer: The internal sixteen-point infrared temperature sensor is extremely useful for understanding the wheel behaviour.
- Weather Station: Provides real time weather information for air pressure, temperature, humidity and air density.
- Multi-Driver Stopwatch: Track up to 4 drivers simultaneously with lap and split times. Ideal for free practice, qualifying and race sessions.
- Data Logger: All the data is recorded and eventually transmitted through Wi-Fi to your Aim Logger in order to have all the information you need when you analyse your data.
Built to Withstand
Equipped with a bright 3.5" TFT IPS display, haptic feedback, USB-C, Wi-Fi/Bluetooth connectivity, and 4GB of internal memory, the MyGauge delivers fast and reliable data in every racing situation. Its Gorilla Glass screen, durable polymer housing, and IP67 rating ensure maximum durability even in harsh track conditions. The intuitive interface, detachable sensor, and ergonomic design make the MyGauge an indispensable tool for any professional motorsport environment.
MyGauge Key Features
- Keyboard with acrylic protection
- Case made of a durable polymer material
- Belt clip for easy portability
- Rechargeable battery
- Gorilla glass for superior protection
- Internal memory (4GB)
- Detachable cable allows use as a standalone stopwatch
- Adjustable sensor for right and left-handed operation
The MyGauge has been built with an internal pyrometer, tyre pressure indicators, the ability to record and transmit data via Wi-Fi to an Aim Logger, and monitoring up to 4 simultaneous lap and split times.
The MyGauge is a vital tool for your track day, free practice, qualifying and race day sessions.
MultiGauge Racing Stopwatch
