Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim MyChron Magnetic Lap Receiver - AimShop.com
    S-MG
    I lager, redo att skickas
    £125.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £125.00
    AiM MyChron Magnetic Lap Receiver
    This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.
    Magnetic lap receiver 712 - 4 pin binder connector
    Suitable for MyChron 4, 5 & 6
    The sensor triggers the timer when it passes over the magnetic timing strip fitted to most kart tracks.
    Replacement sensor for MyChron4
    Compatible with MyChron5
    Triggers lap times from the magnetic strip found in kart tracks
    • 712 - 4 pins Binder Connector
    • 1 x AiM Magnetic Lap Receiver
    • Öppnas i ett nytt fönster.
