Sensor Mounting Kit
This Aim Bracket Kit provides 4 metal brackets designed to convert your existing kart pedal sensors. The kit includes a Brake Position Magnet Holder, Brake Position Sensor Bracket, Throttle Position Magnet Holder and Throttle Position Sensor Bracket, allowing you to mount and align your pedal sensors securely.
Why Choose Aim OTK Kart Pedal Position Brackets
The Aim Pedal Position Bracket Kit allows you to retrofit non-contact pedal sensors on OTK karts with minimal fabrication. Built to withstand the stresses of karting, these strong, race-ready brackets maintain consistent sensor alignment.
This kit is compatible with karting setups that feature Aim’s range of throttle and brake sensors and MyChron (MyChron 4, 5, 6) Lap Timers.
  • Suits Throttle Position Sensor & Brake Position Sensors
  • Suitable for OTK karts
  • Four-piece kit
SKU: B-NC-OTK-K
  • AiM OTK Brake Position Sensor Bracket - AimShop.com
    Bromslägessensorfäste
  • AiM OTK Brake Position Magnet Holder - AimShop.com
    Bromsläge magnethållare
  • AiM OTK Kart Pedal Position Bracket Kit 4 Pieces - AimShop.com
    Gasspjällslägessensorfäste
  • AiM OTK Magnet Holder For Throttle Position Sensor - AimShop.com
    Magnethållare för gasspjäll
