Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim SmartyCam 7-Pin External Power Cable - AimShop.com
    SM-EXP
    Aim SmartyCam 7-polig extern strömkabel
    £40.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £40.00
    Aim SmartyCam External Power Harness
    The Aim SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
    Suitable for all SmartyCam  External power cable 12V
    712 - 7 pins connector Two free wires
    The Aim SmartyCam external power harness can be used to be connected to an external battery.
    The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
    The cable length is 2m.
    • SmartyCam External Power Harness
    • Allows external battery connection 12V
    • 712 - 7 pin male connection
    • Cable length: 2m
    • 1 x SmartyCam External Power Harness
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
