Aim SmartyCam Bullet Cam Mini Roll Cage Mount With Clamp
Mount Your System
The Aim SmartyCam Bullet Camera Mini Roll Cage Mount has been designed to hold and position the bullet camera to a roll bar tube. It is compatible with the SmartyCam GP & Dual 2.1 & 2.2, 3 & 4.
Why Choose the Bullet Cam Mini Roll Cage Mount
The Aim SmartyCam Bullet Camera Mini Roll Cage Mount is manufactured from aluminium, with a black anodised finish and is designed to withstand the rigours of motorsport. The 2 jubilee clips allow for easily fitting the camera to different roll cage tube diameters, and the clamp is available with standard or extended lengths.
Valt kulkamfäste med klämma
44 mm & 55 mm Jubilee Clips
