AiM SmartyCam GP HD Mini Roll Cage Mount with Clamp 2.1 & 2.2 Kart
SKU: SM-VB-GP-S
- Vanligt pris
- £70.00
- Vanligt pris
- Försäljningspris
- £70.00
+ moms (endast Storbritannien)
AiM SmartyCam GP HD Mini Roll Cage Mount With Clamp 2.1 & 2.2
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) mini roll cage mount has been designed to hold and position the bullet camera.
Fits the SmartyCam GP HD camera | Universal rollbar fitment |
Standard or extended length | For SmartyCam GP HD 2.1 & 2.2 |
The AiM mini roll cage mounts have been designed to fit the SmartyCam GP HD bullet camera. This will enable you to mount the camera to a roll bar tube.
The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport.
Provides an easy method of mounting the SmartyCam GP HD camera to a roll cage.
The two jubilee clips allow for fitting to different roll cage tube diameters.
Standard or extended lengths are available.
- Aluminium clamp
- Two jubilee clips - 44mm & 55mm
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) mini roll cage mount has been designed to hold and position the bullet camera.Key Features :
The AiM mini roll cage mounts have been designed to fit the SmartyCam GP HD bullet camera. This will enable you to mount the camera to a roll bar tube.The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport.
Provides an easy method of mounting the SmartyCam GP HD camera to a roll cage.The two jubilee clips allow for fitting to different roll cage tube diameters.
- Aluminium clamp
