Gå till produktinformation
1 av 2
Aim SmartyCam Suction Cup Mount
SKU: SM-WM
Vanligt pris
£60.00
Vanligt pris
Försäljningspris
£60.00
Aim SmartyCam HD 2.1 & SmartyCam 3 Suction Cup Mount
The SmartyCam can be installed using the suction cup mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3 Sport and Corsa models.
Quick and easy to secure
Mounts to a windscreen or flat surface
Easy to move between vehicles
SmartyCam HD 2.1 Compatible
SmartyCam 3 Sport Compatible
SmartyCam 3 Corsa Compatible
The suction cup mount for the Aim SmartyCam is adjustable and holds securely to your windscreen, window or any other flat surface such as a motorcycle fuel tank.
Mounting your SmartyCam is quick and easy. It can be easily positioned as to not get in the driver's way.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3
Suction Cup Mount
Securely attaches to any of your windscreens.
Includes all the fixture and fittings.
  • For use with SmartyCam HD 2.1 & SmartyCam 3
  • Arm height 160mm ( 6.30 inches)
  • 1 suction cup
  • Clamp base with ball
  • 160mm single ball arm
  • 1 ball head
  • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
Technical sheet Race Studio 3
The suction cup mount for the Aim SmartyCam is adjustable and holds securely to your windscreen, window or any other flat surface such as a motorcycle fuel tank. Mounting your SmartyCam is quick and easy. It can be easily positioned as to not get in the driver's way. Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3
Suction Cup Mount
  • 1 suction cup
  • 1 ball head
