Connect Your System
The Aim ECU Plug & Play Cable has been designed to suit Honda motocross bikes and is ideal to use with the Aim Solo 2 DL GPS Lap Timer. It is compatible with the Honda CRF 250cc (from 2010) and the Honda CRF 450cc (from 2009), making it a simple solution for logging your ECU data from your motocross sessions.
Why Choose the Aim Solo 2 DL Plug & Play Cable
The Aim Solo 2 DL Plug & Play Cable suits a variety of Honda motocross ECUs, ensuring that you can easily connect your bike to an Aim Solo 2 DL via a secure 712 7-pin male binder connector. This ECU cable is specifically for motocross environments, so you can be assured knowing that the cable is high quality, reliable and designed to last, allowing you to get your bike's data as soon as possible.
Honda CRF Motocross Bike
Plug & Play Compatibility
This Solo 2 DL Plug & Play Cable is compatible with the following Honda motocross models and years:
  • Honda CRF 250cc – From 2010
  • Honda CRF 450cc – From 2009
If you are unsure whether this ECU cable will fit your motocross bike, don't hesitate to contact our team.
  • For Honda CRF 250cc (from 2010) & Honda CRF 450cc (from 2009) motocross bikes only
  • ECU cable for the Solo 2 DL Lap Timer
  • 7-pin 712 male binder connector
SKU: HON-MX-PP
Användarhandbok för Solo 2 DL Honda ECU
