Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Aim Solo U Bolt Mount - AimShop.com
    SOLO-UB
    I lager, redo att skickas
    £68.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    Product Image
    £68.00
    Aim Solo, Solo 2, Solo 2 DL U Bolt Mount
    The Aim U Bolt mount is suitable for a 0.5 to 1.2" bar, roll cage or railing. Used to secure for Solo GPS lap timer to your vehicle.
    Secure mounting for GPS lap timer Ball & socket for positioning
    Suitable for Solo, Solo 2 & Solo 2 DL 0.5 to 1.2" bar
    U Bolt Mount for GPS Lap Timer
    The Aim U Bolt mount is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
    It is used to mount the Solo, Solo 2 or Solo 2 DL to a roll bar, railing or tube. The U Bolt has a unique ball and socket system that provides a solid mounting and is designed to cope with all Motorsport environments.
    There are two U shaped junctions in the kit which are 2.5cm and 3cm, so the mount can be mounted to different sized bars.
    • 90mm (3.54inches) arm
    • Clamp base with ball 2.5cm and 3cm in diameter
    • U shaped junctions
    • Locknut
    • Screws and washers
    • 1 U Bolt Mount Bracket for Solo, Solo 2, Solo 2 DL
    • Öppnas i ett nytt fönster.
