Aim Taipan Handlebar Switch
SKU: C-HBS
- Vanligt pris
£70.00£84.00(inc VAT)
- Vanligt pris
- Försäljningspris
- £70.00
AiM Taipan Handlebar Switch
The AiM Taipan Handlebar Switch is the best way for changing the behaviour of your bike.
10 LEDs | |
The AiM Handlebar Switch is the best way for changing the behaviour of your bike, it features 2 pushbuttons and 10 LEDs and manages the following settings:
The lower push button on the device is used for changing a feature, while the upper push-button is for choosing one of the possibilities inside the selected feature.
The LEDs on the handlebar switch can be used as a Shift Light Module. Set your required RPM value and the LEDs will start to blink promoting a gear change.
Please Note: The Handlebar Switch is an accessory and you will need to purchase the Taipan ECU and UC-Bridge to enable all the below functions.
Running Maps
Maps are a combination of all the parameters governed by the ECU directly related to engine performance and consist of different tables. The main maps are the fuel and ignition. You can also set up tables of various strategies and sensors.
Fuel Corrections
A correction is the possibility to get a fatter or leaner fuel mixture at different RPM ranges: low, mid and high. The RPM threshold, as well as the percentage, apply along with the default value. This can be done during configuration in maps.
Please Note: Fuel Corrections are enabled in the selected map - this is done during the ECU Maps configuration.
Traction Control
Traction control is used to stop your wheels from spinning when you apply any excess power. You can activate traction control by keeping the lower button pushed down until the green LED beside the TC label appears. To de-activate simply hold down the lower push button.
After pressing down the lower pushbutton and the green TC LED appears, you can select using the upper pushbutton how strong the Traction Control Strategy is supposed to be with (1) being the weakest wheel block to (5) being the strongest wheel block.
Please Note: Traction Control is enabled in the selected map - this is done during the ECU Maps configuration.
Launch Control
The handlebar switch can be used to activate launch control which will assist you to accelerate from a standing start. To activate simply push both the upper and lower buttons on the handlebar switch together, wait a few seconds and the red LEDs will start to blink and the strategy will be engaged.
Please Note: The Launch Control has to be enabled in the selected map - this is done during the ECU Maps configuration.
High Technology 32-bit Core - Optional Extra
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
UC Bridge - Optional Extra
The UC Bridge is the connection between the CAN bus of the ECU and the USB port of your PC. It is available in 2 different licenses :
Tuner License :
Taipan ECU Connections
- JST waterproof connector for CAN Bus communication
- Connector: n.1 JST 04T-JWPF-VSLE-S Connector
- Body: PA6 + 30% glass fiber
- Dimensions: 47.3 x 24.9 x 48.1mm
- Weight: 70g
- 1 x Taipan Handlebar Switch
The AiM Taipan Handlebar Switch is the best way for changing the behaviour of your bike.Key Features :
10 LEDs | |
The AiM Handlebar Switch is the best way for changing the behaviour of your bike, it features 2 pushbuttons and 10 LEDs and manages the following settings:Up to 5 selectable maps
Running Maps
Maps are a combination of all the parameters governed by the ECU directly related to engine performance and consist of different tables. The main maps are the fuel and ignition. You can also set up tables of various strategies and sensors.Fuel Corrections
A correction is the possibility to get a fatter or leaner fuel mixture at different RPM ranges: low, mid and high. The RPM threshold, as well as the percentage, apply along with the default value. This can be done during configuration in maps.Please Note: Fuel Corrections are enabled in the selected map - this is done during the ECU Maps configuration.
Traction Control
Traction control is used to stop your wheels from spinning when you apply any excess power. You can activate traction control by keeping the lower button pushed down until the green LED beside the TC label appears. To de-activate simply hold down the lower push button.After pressing down the lower pushbutton and the green TC LED appears, you can select using the upper pushbutton how strong the Traction Control Strategy is supposed to be with (1) being the weakest wheel block to (5) being the strongest wheel block.
Launch Control
The handlebar switch can be used to activate launch control which will assist you to accelerate from a standing start. To activate simply push both the upper and lower buttons on the handlebar switch together, wait a few seconds and the red LEDs will start to blink and the strategy will be engaged.Please Note: The Launch Control has to be enabled in the selected map - this is done during the ECU Maps configuration.
Tuner License : With this license, the tuner can create different maps, configurations and strategies designed for the rider's bike. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
- Weight: 70g
Video
