Aim Taipan Solo 2 DL Extension Lead
Taipan to Solo 2 DL Extension Lead
The Aim Taipan Solo 2 DL extension lead is a 50cm connection cable designed to connect the Taipan ECU to the Solo 2 DL data logger. One end has a 7-pin 712 male binder connector for the Solo 2 DL, while the opposite ends feature male and female JST connectors for the Taipan ECU.
Why Choose the Aim Taipan Solo 2 DL Extension Lead
The Aim Taipan Solo 2 DL extension lead makes it easier to connect the Solo 2 DL logger and Taipan ECU in your setup without strain on the connectors. Its compact 50cm length offers practical reach for most installations, and the construction ensures dependable performance under difficult motorsport conditions. The cable allows integration into your system, helping maintain organised and efficient wiring throughout your Aim racing setup.
Harness Options
Taipan Solo 2 DL förlängningskabel
Videos
